NI TestStand
How to enable Step Properties
I'm trying to implement Step Properties editor in my custom OI
by using TSUI_CommandsInsertKind (cmds, &errorInfo, TSUIConst_CommandKind_Edit_StepProperties, gMainWindow.sequenceFileViewMgr, -1, "", "", NULL).
Unfortunately the Properties popup  appears with all options disabled.
What is the way to resolve this problem?
(4,649 Views)
Hi YG,
What language are you writing your OI in?
(4,624 Views)
CVI 8.5 and TS 4.1
BR,
YG
(4,622 Views)
Do you have a TestStand user logged in with the correct privileges? If you aren't using user privileges you can disable them with a station option.
-Doug
(4,616 Views)
I've logged as administrator. Please find attachments in order to understand what I mean
YG
(4,613 Views)
Is your OI in editor mode? See ApplicationMgr.IsEditor.
(4,607 Views)
Thanks a lot, James. It's work.
(4,604 Views)
