NI TestStand
How to eliminate an instance of "entering a sequence call" from the teststand report
So far, I am still not getting the correct setting.  Do you have any more information about where to find this setting in the options?
Message 11 of 14
(1,103 Views)
Are you aware of which section in the SequentialModel sequence that this call to the result string occurs?  So far I can not find it.
Message 12 of 14
(1,101 Views)
Have you found the reportgen_txt/atml/xml sequence located in the same directory as the process model? This sequence is called by the process model and calls all the subsequences used to generate the report.
Rodéric L
Certified LabVIEW Architect
Message 13 of 14
(1,093 Views)
Accepted by mcfrenzy36
Thanks!
Message 14 of 14
(1,088 Views)
