How to dynamically create StationGlobal variable
currently i have this statement to set all values in an array:
SetElements(StationGlobals.Project.Serial.Response_Array, "-999")
Now i need to replace the ..Serial.. with Serial0, Serial1, Serial2 where the numeric value is the ThisContext.RunState.TestSockets.MyIndex
How can i define the StationGlobal to use the addidtional MyIndex for the correct container?
(1,432 Views)
You mean, you want each socket execution to create theri respective element in the StationGlobals?
StationGlobals.Project.Serial0
StationGlobals.Project.Serial1
(1,424 Views)
Yes, i have four containers and in each of them an array should be set to -999
(1,417 Views)
//Create the Serialx Container
StationGlobals.NewSubProperty("Project.Serial"+ Str(RunState.TestSockets.MyIndex),PropValType_Container, False,"", PropOption_SetOnlyIfDoesNotExist),
//Create the Array
StationGlobals.NewSubProperty("Project.Serial"+Str(RunState.TestSockets.MyIndex)+".Response_Array",PropValType_String, True,"", PropOption_SetOnlyIfDoesNotExist),
(1,398 Views)
The four containers and the arrays already exist i only want to set the array values to -999
(1,388 Views)
in a statement i want to do this (what is not running):
SetElements(StationGlobals.Project.Serial" + Str(ThisContext.RunState.TestSockets.MyIndex) + ".Response_Array, "-999")
When executing a 4x batchmodel it should set all values in the four arrays to -999.
The four StationGlobal arrays already exist
StationGlobals.Project.Serial0.Response_Array
StationGlobals.Project.Serial1.Response_Array
StationGlobals.Project.Serial2.Response_Array
StationGlobals.Project.Serial3.Response_Array
@Olil_Wachno, in your reply i can only see four lines in the code, are there more lines hidden after the comma?
(1,287 Views)
Accepted by OnlyOne
OK, this one took me a bit at first 🙂
If you look at the description
the first argument of function is an Array. You gave it a string.
To get the Array which the from the String is  referring to, you can use the Evaluate() function like so
Only those four lines, I misunderstood your question thinking you were asking on how to create the data structure programmatically.
(1,279 Views)
