03-23-2020 03:39 PM
I'm using default Full Feature Operator interface for the TestStand deployment (steps are in LabView).
But I don't want the operator has an option to terminate the test after he/she starts the test (after pressed "Test UUTs").
How can i disable that button?
03-23-2020 10:50 PM - edited 03-23-2020 10:52 PM
Hi Armitakh,
I open the default Full Feature Operator interface and see how it run. The "Terminate" button will appear until a person press button of "Test UUTs" and disappear when the program is finished. So I think the easiest way to do is move Terminate button away form the windows.
Or you just want to disable it in the period of execution, you can use callback function (Start execution and End execution) to make it temporarily disable.
Ricky
03-24-2020 12:17 AM - edited 03-24-2020 12:21 AM
Another option is to remove the privilege from the Operator in the users.ini file. Then they can't click on it. Also, this way you don't have to edit the UI at all.
03-25-2020 05:19 PM
Thanks Jigg for the help.
So should i change Terminate to "True"(below image), because currently it was false and showed the "Terminate" button
03-26-2020 07:45 AM
Hello Armitakh
Change the value for Terminate from True to False.
(Groups → Privileges → Operate → Terminate)
Chris
03-26-2020 11:58 AM
@Chris_Märki wrote:
Hello Armitakh
Chris
This will change it for all operators. Which if you want then go this route. If you want to just change it for a single person then remove them from the operator group and set the individual privileges as desired.
