04-08-2026 10:47 AM
Hello all,
I'm evaluating if our sequence files created using TestStand 2016 are compatible on latest Test Stand.
I keep seeing "Object reference not set to an instance of an object" popup message when closing the application. Screenshot attached.
I suspect that this is somehow related to sequence file conversion from older TS to newer, but I have no idea where to look. Is there any log file to which Test Stand is logging more verbose messages? I checked event viewer and as it seems, there are no Test Stand related logs.
Sequences often use .net adapters. We don't use LabView or similar adapters
workflow:
1. Use Sequence file converter converter to convert all files from format version 16 to format version 23
2. Open TestStand (using env flag and custom "start in" path with specific folder where sequence files are stored)
3. Open sequence file.
4. Close
5. Errors:
5.1
5.2
6. Start plain SeqEdit.exe, without env flag., no custom process model is loaded
7. Close
8. Error same as in 5.1, but without 5.2
Doing same set of steps using TS2016, using same sequence files don't trigger any error
How to troubleshoot this?
Thank you
04-09-2026 12:03 AM
I suggest to first chech the actual error message, which gives you the top level objects.
Can you share the full path?
04-09-2026 12:35 AM
sorry about that, it is: AppData\Local\National Instruments\TestStand 2026 (64-bit)\SeqEdit.xml
I tried to delete it, but nothing id changing
04-09-2026 12:43 AM
Don't know, if this really matters....but maybe worth asking: is TS2016 32 or 64 Bit?
If it is 32 Bit, have you tried to import the old seq files with the currenct 32Bit version?
04-09-2026 01:26 AM - edited 04-09-2026 01:27 AM
Both are 64 bit
04-09-2026 11:03 PM
That file is what is saved when configuring the Sequence Editor settings. I suspect that either this is a bug in the Sequence Editor, or something is occurring on shutdown that is causing the process to incorrectly shutdown and it fails to release that file. If you delete the file, I believe that the Sequence Editor will generate one with defaults on the fly.
The only thing I can think of is to determine what actions in the Sequence Editor make this dialog appear and try to figure out if there is anything you are doing that might affect that file reference, unlikely.
If this is the only file leaking, it is a bounded leak and likely can be ignored. FWIW, you can turn off displaying this dialog using Configure>>Station Options>>Preferences Tab>>Debug Options>>Report Object Leaks.
04-10-2026 11:05 PM
Thinking about this more resulted in a few more thoughts:
