Hi Petri,
Basically, there's no way of getting the status of a step run allready into another sequence, and having results disabled.
However, I modified your sequence as follows so you can get what you need:
1. In the subsequence, I added the PostExpression "RunState.Caller.RunState.Step.Result.Status = "Interrupted"" which has as a result the modification of the sequencecall step in the MainSequence to have the status "Interrupted"
2. In MainSequence, I changed the PostExpression to check the status of the sequence call, now reflecting the "Interrupted" status for the measurement.
Please have a look at the attached modified sequence.
Hope this helps,
Silvius
Silvius Iancu
