05-15-2019 02:44 AM
in the normal "Message Popup" teststep i can set up to 6 buttons.
Is there a way to increase this? I need ~10 buttons.
Thanks for help
Solved! Go to Solution.
05-15-2019 03:30 AM
Hi OnlyOne,
You can find my solution to this problem here: Re: Message PopUp Maximum Button
I hope this helps,
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
05-15-2019 04:05 AM
In most cases, you would implement a custom module for this.
The main reason is that a popup with >5 buttons is already VERY questionable. The main reason is: You have FIVE different options to CLOSE the dialog. As a user, i dislike designs like that a lot.
I recommend to create a module with checkboxes or radio buttons and only up to three "normal" buttons (OK, Cancel, Help).
