NI TestStand
How to copy Step.Result.Error.Code to Local Variable
How I can copy Step.Result.Error.Code for a particulat step to a Local variable.
I want to print the value of Step.Result.Error.Code  in my test report.
Please help. thanks in advance.
Sagar Joshi
(3,608 Views)
Hi Sagar,
You could copy the error code to the ReportText, using the following post-expression:
Step.Result.ReportText = (Step.Result.Error.Occurred == True ? "Error Code: "+ Str(Step.Result.Error.Code) : "")
Charlie
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(3,605 Views)
Thanks  CharlieRodway, But I guess the post expration will not execute if any error occure while executing the step. Right?
I earlier used following expration in post expration. Nut I saw that the Local variable is not updating on Step failure.
Local.StepErrorCode = Step.Result.Erroe.Code
(3,602 Views)
Hello CharlieRodway,
I tried your solution but the Post Expration is not executed when the step if failed.
When I am monitoring the Step.Result.Error it has updated the error code. Msg and Occured to True, But the Result.ReportText is not updated.
It means that the Post expration is not executed when the Step is failed.
(3,595 Views)
Accepted by joshisagarr
Yes, of course!
This is best handled by the SequenceFilePostStepRuntimeError Callback:
1). Add StepResultCode (Number) to FileGlobals
2). Add SequenceFilePostStepRuntimeError Callback to your sequence file
3). Add the following Statement step to the SequenceFilePostStepRuntimeError Callback:
FileGlobals.StepErrorCode = Parameters.Step.Result.Error.Code
Here's a snapshot of the sequence:
I hope this help,
(3,594 Views)
Thanks a lot Charlie Rodway
(3,588 Views)
