NI TestStand
How to convert Test Executive 4 sequence file to TestStand 3.0 or 3.1?
Is there any way to convert Test Executive 4.0 sequence file into TestStand 3.0 or 3.1 format? I found a converter vi here, but it only takes the file made with TE/LV 5.0 or later. Thanks.
(3,321 Views)
I'd ask NI very nicely for a free loan of the newer test executive!  As it's only for converting to TestStand and TestExec is now a museum piece, they'll probably let you borrow it.  Or they may even do it for you.
Might be worth speaking to your NI rep - presumably he's had a few lobster lunches from the commission from your sales.
Otherwise - re-write your sequences.  This might be quicker anyway, depending on the length of your sequences.
(3,316 Views)
CT,
I suggest creating a Service Request and contacting NI via e-mail or phone support.  (Go to http://www.ni.com/support/).  We cannot provide you with software, but we may be able to help you convert your files.
Tyler T.
(3,280 Views)
