12-09-2011 04:06 AM
Hello all,
I am trying to develop test scripts in ATML standards. I need to call a function in DMM.dll file. How can i do that in ATML standards, please explain with some example ATML standard XML file. Someone please help me in doing so. Thanks a lot in advance.
With Regards,
kalyan
12-13-2011 01:28 PM
Hi Kalyan,
For clear understanding of your use case, I request you to clarify the following:
1. By test scripts in ATML standards, do you mean the ATML Test Description (TD) file?
2. Can you give me more information regarding when the function is to be called?
12-14-2011 12:37 AM
Hi srivinayak,
Yes by the name "Test Scripts in ATML Standards" means ATML TD file. I want to develop test scripts for a UUT. Some voltage is generated by SORENSEN DC powersupply, I need to measure that voltage dynamically in DMM. Thanks a lot for responding.
With Regards,
kalyan
12-14-2011
03:41 AM
- last edited on
02-18-2025
02:23 PM
by
Content Cleaner
Hi Kalyan,
Thanks for clarifying on the use case. You can use NI TestStand ATML Toolkit 2010 to translate the ATML TD file to a TestStand sequence file.
There are two ways to achieve the expected behavior based on the application you used to create your dll.
12-15-2011 10:55 PM
Hi srivinayak,
Thanks a lot for your reply. It is really a helpful solution. As per your solution we can call functions of the same dll which we have specified in the code module settings. But according to my requirement i need to work on two or more instruments in the same test script, then how can we call two or more dll's in the same test script. Please give corresponding solution to my requirement. Once again thanks for responding.
Thanking you,
With Best Regards,
Kalyan
12-16-2011 12:50 AM
Hi Kalyan,
In case you need to call functions from different dlls, you can use the solution 2 mentioned in my previous reply. Solution 2 works in case of single or multiple dlls irrespective of whether or not the NI's LabWindows CVI application was used to create the dlls.
12-19-2011 10:30 PM
Hi srivinayaka,
I am attaching the XML file i have written in ATML standards and the Labwindows/CVI code that was generated when the XML file is opened in TESTSAND. actually the defenition of the function "IALdcpwr_reset()" is in IALdcpwr.lib and IALdcpwr.h files.
"How can we add this library and header files?" so that i can show the path of definition. whether it should be done manually or can we do some changes in the XML file and make the work done?. Thanks in advance. If you have any example for this type of sequences. please forward me which would be helpful for me.
With best regards,
kalyan
12-19-2011 10:34 PM
Hi srivinaya,
In my last post i have attached only the XML file. sorry for that. please find the Attachment of generated Labwindows/CVI code.
with best regards,
kalyan
