NI TestStand
How to automatically run specific sequence file when Labview TS user interface is open
When using Labview TestStand simple/full-featured user interface, It is not so elegant that user have to search for the sequence file and then press Test UUTs button to load sequence file...
How this can be done automatically? For example, I Build EXE from Simple user interface. Renamed build something like "MyTesting_Application1.exe" When User runs this application, the program should automatically  load Seq. file saved in C:\\
(1,157 Views)
Accepted by topic author AndrazS
One option would be to create a shortcut instead of rebuilding it- the shipping example user interfaces come with shortcuts to specify editor or operator modes:
There are a bunch of command line arguments you could use, including ones for loading and running sequence files:
https://zone.ni.com/reference/en-XX/help/370052AA-01/tsfundamentals/infotopics/startup_opt/
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(1,132 Views)
