NI TestStand
How to add custom step type in insertion palette
I was Working on Creating an new Custom Step type in Insertion Palette.I Tried it by CTRL + T, Types: MyTypes.ini Tab got opened
Under MyTypes.ini in StepTypes, Inserted a New StepType -> go to properties -> Substeps -> Add -> Update specific module.
i am following above procedure but when i am updating specific module getting error. i have attached error image.
Let me know i have follow procedure properly to create custom step type or i did any mistake?
Help me out to include custom step type in insertion palette.
(2,922 Views)
In order to place a custom step type in a well-defined tree structure of the insertion palette, i recommend you to modify the insertion palette rather than to rely on step type configurations.
You can right click the insertion palette and select "Customize..."
Norbert
Expert: Geometry
(2,902 Views)
