NI TestStand
How to Read and Write 2D Array from Teststand in Labview using Set and Get property Value method
Hi All,
I am trying to read 2D Array from from Teststand using  "Get Property Value"  VI Function in labview
but I am facing error.
Thanks in advance ,
SV.
Message 1 of 8
(1,638 Views)
Its Quiet Possible , using Get/Set Val variant (In Property Object).
Its always good to share the code you developed and the error you are facing to get the proper response.
Pazhanivel Thiruvenkadam,
CertifiedLabVIEWArchitect|| CertifiedTestStandDeveloper,
Currently able to Access LV2015&LV2017
Message 2 of 8
(1,619 Views)
i am using normal Teststand API Function to test.
Message 3 of 8
(1,612 Views)
You can create your own Module for this purpose in LabVIEW
Snippet to Set Value.
Message 4 of 8
(1,605 Views)
Is this function will set and Get 2D Numeric Array Value from Labview to Teststans ?
Message 5 of 8
(1,599 Views)
I have used and worked fine for 1D Array, same should work fine for 2D Array so that's the reason we used Variant instead of Specific type.
Message 6 of 8
(1,596 Views)
Yes , its works fine for 1D Array, but 2D Array it shows error
Message 7 of 8
(1,589 Views)
Checked and works fine Even for 2D Array. Please Make sure you have created Variable with 2D Array and Calling Proper Names.
Its Better to share the Code which you have tried for better update.
Message 8 of 8
(1,576 Views)
