03-20-2018 11:51 PM
Hi All,
I am trying to read 2D Array from from Teststand using "Get Property Value" VI Function in labview
but I am facing error.
Thanks in advance ,
SV.
03-21-2018 01:35 AM
Its Quiet Possible , using Get/Set Val variant (In Property Object).
Its always good to share the code you developed and the error you are facing to get the proper response.
03-21-2018 03:28 AM
i am using normal Teststand API Function to test.
03-21-2018 03:32 AM
You can create your own Module for this purpose in LabVIEW
Snippet to Set Value.
03-21-2018 04:22 AM
Is this function will set and Get 2D Numeric Array Value from Labview to Teststans ?
03-21-2018 04:44 AM
I have used and worked fine for 1D Array, same should work fine for 2D Array so that's the reason we used Variant instead of Specific type.
03-21-2018 09:21 PM
Yes , its works fine for 1D Array, but 2D Array it shows error
03-22-2018 08:51 AM
Checked and works fine Even for 2D Array. Please Make sure you have created Variable with 2D Array and Calling Proper Names.
Its Better to share the Code which you have tried for better update.
