How to Find Size of a String in TestStand
I have a String ouput coming from a LabVIEW module. I want to read the Size of the response string and check it against a fixed value and if its greater than, then return pass else failed. How do I read the Size of a String in TestStand? Is there a property available for it or a inbuilt function?
(1,377 Views)
Accepted by topic author VBajaj
Use the Len() function to get the string length.
Santhosh
Soliton Technologies
Only two ways to appreciate someone who spent their free time to reply/answer your question - give them Kudos or mark their reply as the answer/solution
(1,364 Views)
