01-06-2012 11:31 AM
Hi Luke,
I cannot open the attached sequence file. File Format Error - the file is not a sequence file
Error Code: 17100 incorrect format Source:”TSAPI”
Please advice. I’m using TestStand 3.1.
Henry
01-06-2012 12:17 PM
Here's the file saved for TestStand 3.1
01-06-2012 01:38 PM
Hi Luke,
I see the same problem. Please see my modified “test” sequence “Computer.seq”.
My TestStand GUI is set to “report.xsl”. I would like to dynamically change to “expand.xsll”
Henry
01-06-2012 03:51 PM
Hey Henry,
Check your report options and verify that the report format is xml. I think the default might be html for 3.1
Luke W
01-06-2012 04:18 PM
Hi Luke,
Do you mean Report Options in TestStand GUI?
What about if TestStand GUI is set to ASCII Text file?
Can you make my test sequence “Computer.seq” work correctly?
Henry
01-06-2012 04:22 PM
Hey Henry,
That is what I'm referring to, yes. The Stylesheet only seems to apply to XML and ATML formats. Are you restricted to using ACII for some reason?
Luke W
01-09-2012 05:45 PM
Hi Luke,
After I switched my GUI default from ASCII to XML, the Report Options call back is working correctly.
I have been using ASCII because it is easy to share test reports, but now I was asked to switch to XML format.
You have been very helpful, you are the best!!
Thank you very much,
Henry
