05-18-2011 12:50 PM - edited 05-18-2011 12:52 PM
I'd like to create a VI that will return all the VI paths that are associated with the test steps in a TestStand sequence. How do I return the VI path associated with a test step? Below is a starting point that returns the first step in the sequence.
05-18-2011 01:08 PM
You need to convert the Module to a LabVIEWModule (use the Variant to Data node), then you can use LabVIEWModule.VIPath. If you are using TestStand 2010, you can call LabVIEWModule.GetVIAbsolutePath to find the VI in the case you are calling it with a project.
05-18-2011 01:31 PM
Thanks a lot, Allen. Exactly what I was looking for. Here is the code that worked:
07-07-2020 08:29 AM
Hi guys,
I know that this thread was solved, but I have the same problem, and I do not know how to find this particular constant type (TSAdp.LabViewModule).
Thank you in advance.
