10-21-2015 02:15 AM
10-21-2015 08:04 AM
Do you want it to be a separate dialog? Do you want to use a control on the UI? Do you want to use the built in Status Bar progress?
The full-featured UI already has the status bar and you can update it with the following UI Message:
UIMsg_ProgressPercent–(Value: 11) TestStand step modules post this message to the user interface to notify it to update the progress indicator associated with an execution. The activeXDataParam parameter specifies an execution. The numericDataParam parameter specifies a value from 0 to 100 that indicates the percentage of progress the current execution reports. This value indicates the progress of operations for which the execution chooses to report the amount of progress. The value does not necessarily reflect the progress of the execution as a whole.
10-21-2015 09:01 AM
I would like to use the built in status bar. Could you explain it step by step? For example, I inserted an expression step. What would I need to type in to the expression in order to change the progress on the built in status bar? A link to an example would be great too. Thanks
10-21-2015 03:19 PM
I threw this together. Let me know if it is enough or if you have questions.
10-22-2015 02:12 AM
Yup, that answers it exactly. Thank you very much!
06-30-2023 12:56 PM
What if I need a Separate Dialog box,
My requirement is to show a separate dialog box with the progress of steps.
