NI TestStand
How do I detect if a TestStand execution has been terminated?
We have written a custom GUI that interfaces with TestStand to invoke and control the execution of sequence files.  During an execution, the operator can click on a STOP button which causes the following code to be executed:
        this.myExecutionViewMgr.GetCommand(CommandKinds.CommandKind_Terminate).Execute(true);
This works OK and the TestStand execution is terminated.  However, the EndExecution event handler is not telling me that the execution was terminated.  Here's what our code looks like:
        void EndExecutionEventHandler(object sender, EndExecutionEvent ev)
            // This line ALWAYS returns PASSED or FAILED
            this.Status = ev.exec.ResultStatus;
            // The error object doesn't occur when I terminate
            PropertyObject errorObj = ev.exec.ErrorObject;
            if (errorObj.Exists("Occurred", 0) && errorObj.GetValBoolean("Occurred", 0))
                string errorCode = errorObj.GetValNumber("Error.Code", 0).ToString();
                string errorText = errorObj.GetValString("Error.Msg", 0);
                MessageBox.Show(errorCode.ToString() + " - " + errorText);
Is there a way to identify if an execution was terminated, aborted, etc?
(7,169 Views)
You can check it from your "UIMessageEvent" event from your Application Manager , usually when you terminate the execution it will throw an event
UIMessageCodes.UIMsg_TerminatingExecution.
if (e.uiMsg.Event == UIMessageCodes.UIMsg_TerminatingExecution)
      //This is giving you the idea that the execution was terminated.
else if  (e.uiMsg.Event == UIMessageCodes.UIMsg_AbortingExecution)
      //This is giving you the idea that the execution was aborted.
Message Edited by -mbda- on 05-13-2010 08:34 AM
(7,160 Views)
Accepted by topic author tlaford
You can also use Execution.GetStates and look at the termination state to determine if it was terminated.
-Doug
(7,149 Views)
I changed my EndExecutionEvent Handler method to the code below and it works great!
            ExecutionRunStates runState;
            ExecutionTerminationStates termState;
            ev.exec.GetStates(out runState, out termState);
            if (termState != ExecutionTerminationStates.ExecTermState_Normal)
                this.Status = "ABORTED";
(7,140 Views)
