NI TestStand
How do I configure TestStand 3.1 to use the lvrt.dll instead of the TestStandLVRTS.exe?
TestStand 3.1 no longer closes the runtime server when it quits and the soluton is the following:
In TestStand 3.1, you can now use the LabVIEW 7.x run-time DLL which runs in-process to the TestStand application, no external EXE server is necessary.
OK.
How do I do this?
(3,405 Views)
Hi Kendrick,
Go to 'Configure'>'Adapters'
Select 'LabVIEW ' and [Configure...]
Check the 'LabVIEW Run-Time Engine' box and select the version
Hope it helps,
<<-N->>
(3,399 Views)
Unfortuanetly I am stuck with the TestStandLVRTS.
However, "taskkill /f /im TestStandLVRTS.exe" works.
I ran across a message that said you have to kill the process now.
THANKS.
(3,370 Views)
