NI TestStand
How do I Launch a Microsoft WORD Document using AciveX from testStand
Hello All:
I would like to launch a Word document from within Teststand. I would also like to have the ability to search the document for particular sections of the document. I can not find any sequence file examples that even comes close to demonstrating any of this.
Thanks...
(3,753 Views)
Hello Craig,
I have attached an example that will demonstrate this for you. You may need to change the Word Server to match the version of Word that you have installed. This can be done by right clicking on each ActiveX step and select Specify Module. Under Automation Server, scroll down the list to Microsoft Word... and select it.
This is primarily an example to demostrate calling Microsoft Word from TestStand. If you require additional functionality from the Microsoft Word ActiveX server then you should refer to the API reference help for Microsoft Word.
Hope this helps!
Bob
(3,753 Views)
Thanks Bob.
Perfect. I was close, but this was just what I needed.
(3,753 Views)
