11-16-2017 10:23 AM
i have two StationGlobals (numeric):
StationGlobals.One
StationGlobals.Two
And there is a FileGlobal.parameter (string) that contains the text "One".
How can i set an expression using something like:
StationGlobals.+FileGlobals.parameter = 12
So the second part of the StationGlobal is defined by another variable.
Solved! Go to Solution.
11-16-2017 01:40 PM
StationGlobals.GetValNumber(Fileglobals.Parameter, 0)
11-16-2017 01:42 PM
Sorry you probably want this:
StationGlobals.SetValNumber(FileGlobals.Parameter, 0x4, 12)
11-20-2017 04:46 AM - edited 11-20-2017 05:04 AM
solved.
thanks
