01-31-2017 08:00 AM
I have the DAQ plotting the whole 16 bit word but I only need to see a single bit in the word transition from 0 to 1. Is there any way to mask the bit?
I am using Test Stand 2013.
Tom
Solved! Go to Solution.
02-01-2017 02:21 AM
Tom,
first of all, TestStand doesn't acquire data by itself; you require a code module for this.
Second: Are you talking about a digital signal? If not, your request doesn't make much sense as a toggle of a specific bit is either
a) passing a threshold (simple greater equal comparison) - or -
b) simply nonsense as the bit might be subject of expected measurement inaccuracies (typically the lowest 2-3 bits)
02-02-2017 08:34 AM
I agree with Norbert here we need some more context on how this data is being collected and then passed to TestStand so that we can fully understand why/how this bit will need to be represented.
02-08-2017 09:52 AM
Worked around the issue in the software instead of trying to mask the bits. This was a 16bit word representing a bunch of different flags. I.e. Bit 2 is a discrete that indicates weight on wheels. I am using the DAQ Plot to show exactly when the WOW bit is set or cleared. In Test Stand this word gets stored in a Local variable say
Flags. That part is working fine. Can I now use an expression to mask off
bit 2 and store it in a local WOW_flag variable? In C it would be WOW_flag = Input_word & 0x0004. Just didn't know if Test Stand can do this type of expression.
02-09-2017 04:13 PM
Hey TomMills,
There is not a function to do bit masking in TestStand. You should do this in the code module itself instead. What type of code module are you using to actually get this data?
