To BMas05 -
Yes if you set,
Setting: "Exiting"
Condition: "When Executing"
Time Limit: "2"
Action: "Terminate Execution"
On shutdown, if an execution is running for more than 2 seconds after shutdown is initiated, TestStand will attempt to terminate the execution.
Now if you wanted to escalate terminations that take too long you could additionally set,
Setting: "Exiting"
Condition: "When Terminating"
Time Limit: "4"
Action: "Abort Execution"
So now on shutdown, if an execution is terminating for more than 4 seconds after termination is initiated on shutdown, TestStand will attempt to abort the execution.
Now if you wanted to escalate aborting executions
Setting: "Exiting"
Condition: "When Aborting"
Time Limit: "6"
Action: "Kill the Execution's Thread's"
So now on shutdown, if an execution is aborting(typically unresponsive) for more than 6 seconds after abort is initiated, TestStand will attempt to kill the unresponsive thread.
Scott Richardson (NI)
Scott Richardson
