NI TestStand
How can I report a step only if it is failed?
In order to decrease the file size of my reports, I would like to only report certain Numeric Limit step results when they are failed.  Can someone tell me how to do this in the step itself?
(3,358 Views)
See this post if this is what you are looking for.
CLD
(3,356 Views)
Hi jnclaker,
Hopefully the forum post that Lvrat linked you to is helpful. If you choose to use the Result Filtering Expression to exclude failing steps from your report, please keep in mind that this feature is not available for reports with an XML format.
Jackie
DAQ Product Marketing Engineer
(3,332 Views)
