07-22-2021 12:03 PM
Hello All,
I'm wondering if there is a property available such that I can access the value of an output from a code module (without assigning/saving it to a variable).
Say, output from a code module will be an input to another code module.
Hoping for something similar to "".
May be starting with "RunState.Sequence.Main["Pass/Fail Test"]........"
Solved! Go to Solution.
07-26-2021 09:56 AM
You HAVE to assign it to something to access it. Otherwise you are just accessing nothing. So basically you have code module A and code module B and you want to take an output from A to B. You still have to assign the output of A to something. You can't just leave it blank.
Even if you assign it to a step property it needs to be assigned.
08-13-2021 12:36 PM
Hello jigg,
Thank you for taking out time and replying to my query.
I was thinking if inputs/outputs from a code module are being collected automatically and I could access it without assigning to any variable. Guess its not the case.
Thanks again.
08-13-2021 02:12 PM
For completeness, I should mention that if you click the log checkbox for a parameter or return value, it will be stored in the results. I did this for a return value of a dll call and it was stored at:
Locals.ResultList[<index of result for step in question>].AdditionalResults["Parameters"]["Return Value [Out]"]
I got that path by break pointing after the step and inspecting Locals.ResultList in the variables view.
08-13-2021 03:38 PM
Hi James,
Thanks for sharing info. Although, in my requirement, I actually don't want some of these outputs (from code module) to be logged. Just want to access it for some calculations (in subsequent steps).
Thank again.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
