05-20-2008 12:05 PM
05-21-2008 12:42 AM - edited 05-21-2008 12:42 AM
If you are using TS 4.x, you can use the horizontal XML format report. Otherwise you will have to modify one of the report generation sequencefile (probably the text version) to produce the effect you require.
Regards
Ray Farmer
09-22-2008 09:14 PM - edited 09-22-2008 09:19 PM
I would have figured this to be a pretty common use case, so I was wondering if anyone has made/edited a report sequence that does this?
For example, the default report text looks something like:
UUT Report
Serial Number: MACADDRGoesHere
Date: Monday, September 22, 2008
Time: 9:48:05 PM
Operator: administrator
UUT Result: Passed
Begin Sequence: MainSequence
(C:\Projects\Corventis\1-08-01641-Corventis-Gen1 PCBA Test System\Engineering\3 - Develop\Sandbox\Report Generation Demo\Report Generation Demo_Main.seq)
V_CPU_2V5 (Device Off): Passed
Measurement: 0.3000
Units: V
Limits:
Low: 0.1000
High: 0.5000
Comparison Type: GELE (>= <=)
Module Time: 0.0014
Memory DataBus Test POST: Passed
Module Time: 0.0012
V_BATT: Passed
Measurement: 3.1200
Limits:
Low: 3.0000
High: 3.2000
Module Time: 0.0009
End Sequence: MainSequence
End UUT Report
whereas I'd love something like:
UUT Report
Time: 9:48:05 PM
Execution Time: 0.2188 seconds
Test Name Result Measurement Units Limit Low Limit High Comparison Type Module Time
V_CPU_2V5 (Device Off) Passed 0.3000 V 0.1000 GELE (>= <=) 0.0014
Memory DataBus Test POST Passed N/A N/A N/A N/A N/A 0.0012
V_BATT Passed 3.1200 3.0000 3.2000 GELE (>= <=) 0.0009
End UUT Report
