03-30-2010 08:08 AM
How can I programmaticaly insert a step of type (Sequence call) inside a sequence ? I also need to specify module to the current sequence file and select the sequence to call. I also want to be able to pass some parameters to the called sequence.
Attached is a snap shot of how I attempted to do it based on an example done using C#.
Sam
03-30-2010 08:29 AM - edited 03-30-2010 08:29 AM
Have you loaded the type palette using Engine.LoadTypePaletteFilesEx
Regards
Ray Farmer
03-30-2010 08:34 AM
I figured out how to create the step of sequence call by using the method IEngine.NewStep ("Sequence Adapter", "Sequence Call"), but the issue now is to specify module. The method Step.SpecifyModule launches a dialog, but I want to do that silently and also pass some parameters.
Sam
04-08-2010 09:18 AM
