What you can do, is use the Override Callbacks for Modify the Report that is Generated.
Also you can also change the report sequence 'reportgen_txt.seq' to achieve the desired affect. If you go for modifying the report sequence then copy this to the User folder and then make your changes.
In the Resources Library you can find simple examples were the report has been modified by either using the Override Callbacks or by modifying the actual sequence.
One other item in the Report Options you will have to set the 'Select a Report Generator for Producing the Report Body' control to use the Sequence instead of the DLL.
Hope this helps
Ray Farmer
Regards
Ray Farmer
