NI TestStand
How can I convert a bunch of ini sequence file to binary?
I've used to 'Tools'>'Update Sequence Files' to convert my files from 3.5 to 4.0. Is there a way to convert them all to binary at once?.
The 'Sequece File Properties' points me to the 'Update Sequence Files' tool but I don't see how, perhaps I have an old/eval version?
(3,966 Views)
That screenshot is of the 3.5 Update Sequence Files tool.  Choosing that tool item in 4.0 launches a new tool. In the 4.0 tool, enter your top level directory and select Edit>>Select All Sequence Files. Next, right click on a selected file and select Change Format>>Binary. Now select Edit>>Apply Changes.
(3,952 Views)
Well, that's the tool that my TS4.0 launches... do you knwo if they recently changed it?
Message Edited by << - N - >> on 11-07-2007 11:35 AM
(3,947 Views)
This is the call to the tool...
Message Edited by << - N - >> on 11-07-2007 11:45 AM
(3,939 Views)
I'm not sure why your tool menu item points to the old tool. Did you migrate a 3.5 tool menu configuration?
Anyway, make a new tool item, or edit the existing one to launch:
<Program Files>\National Instruments\TestStand 4.0\Bin\SequenceFileConverter.exe
Message Edited by James Grey on 11-07-2007 01:47 PM
(3,935 Views)
That fixed my problem.
Thanks (=
(3,914 Views)
