How can I change the labview adapter active-x server using API. I already tried Adapter.Configure() but I need other solution.
Currently there is no way of changing the LV adapter using the API. You can change value in the testexec.ini file, however, this chane will not take affect until TS is relaunched.
(2,796 Views)
