How can I access to the limits of a numeric limit test with TestStand API?
I need to acces and save all the limits of a teststand sequence and save it to a log file, I export the documentation to a text file but doesn't import the limits just the name and description.
I read that I can access to them with the TestStand API, but there's an infinite number of propertys on the sequence context in property node and I don't find the correct one to save the limits. Can it be done with the API?
Ing. José Antonio Páez López
Functional Test Engineer & CLAD
(2,670 Views)
There's actually a built-in way to export limits:
  • Tools » Import Export Properties
  • Choose Export in the tree
  • Fill in a Destination Location
  • On the Property Selector tab, click the filters icon
  • Choose Limit Properties
  • Check the steps/limits you care about and hit Export.Export.PNG
If you still want to go the API route, you need to get a reference to the Step object, and there is a limits container under that.
Hope this helps!
Trent
(2,667 Views)
I want to perform it in a automatic way, so there's not an object reference that point to the step limits in the API.
(2,637 Views)
It sounds like you're looking for the Step.Limits Container i mentioned:
Getting a reference to all of the steps is the trickier part. This example should help:
https://forums.ni.com/t5/Example-Programs/Creating-a-Sequence-File-Iteration-Tool-Replacing-Absolute...
(2,620 Views)
