NI TestStand
How can ı Customize report only one table for all the sequence steps
I Need to customize the XML Teststand report.  I am working on horizontal.xsl stylesheet file. I need to output only one table for all the sequence steps. How can ı do it?
(2,217 Views)
You can do this by customizing the XML Stylesheet.
Here's another post about this:
https://forums.ni.com/t5/NI-TestStand/Prevent-xml-stylesheet-teststand-from-creating-tables-for-flow...
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(2,200 Views)
This is not solution for me. I want to print one table. Is there any solution about this?
(2,193 Views)
