06-27-2012 09:41 AM - edited 06-27-2012 09:42 AM
How is inserting a sequence call and looping on it complicated?
Or better yet, just uses the Test UUTs entry point of the process model if the loops are for separate UUTs. That's what it's for. What fundamental functionality do you feel teststand is missing?
-Doug
06-28-2012 04:22 PM
Hi Doug,
Maybe I was improper with my verbage as this obviously came off harsh. My apologies.
I should have described in more detail. In many of the automated test environments we use, there is already a option dialog with something like:
Loop:
a. Continuous
b. x Times
c. Until fail
Do all (do not stop on fail)
I understand that it's not difficult to implement, would just be a good feature to have built-in.
Patrick
06-29-2012 04:15 AM
You just need to insert a sequence call to the sequence you want to loop, then you can set the same standard loop options like in every other step.
The available looping options are almost the same you described here.
Alex
06-29-2012 06:52 AM - edited 06-29-2012 06:54 AM
Alex
And here's a picture of the built-in feature.
06-29-2012 09:52 AM - edited 06-29-2012 09:59 AM
Like Alexander and Paul explained, such a feature as you are asking for already exists, both in the normal execution case, and in the interactive execution case. Here is the loop options for the normal execution case (see attachment).
This should allow you to easily do everything you mentioned.
-Doug
06-29-2012 10:54 AM
Alex, Paul, Doug,
Thanks for the info and easy solutions! There are a few different ways to quickly implement it seems. Just a matter of time before I actually know what I'm doing. Ha.
Thanks again,
Patrick
