NI TestStand
How Do I Disable UUT Serial Number Dialogue Box?
Hello TestStand Gurus,
I have a simple sequence that pops up a dialogue box stating: "Enter Your Name."
Problem: When I run this sequence, the TS dialogue box "Enter UUT Serial Number" comes up before mine.
Figure 1: My simple pop up sequence
Figure 2: TestStand Popup
Questions:
1. How do I disable the TS dialogue box so only my pop up is displayed?
2. How can I make my sequence stand alone? e.g. If its part of a main sequence file, not to get executed unless the user clicks a button from an external program e.g. a GUI from LabVIEW?
Thanks!
(7,395 Views)
You need to override PreUUT callback: http://forums.ni.com/t5/NI-TestStand/Intercept-the-PreUUT-callback/td-p/998605
That's where the dialog is coming from.
For the UI stuff check this out:
http://www.ni.com/white-paper/7560/en/
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(7,386 Views)
Thanks for the info! I added the PreUUT and disabled it. Is this what you recommend?
(7,377 Views)
Meaning I added the PreUUT callback and chose Run Mode>Skip. Is this what you meant by overriding it?
(7,372 Views)
No. By adding the callback, you override the built-in dialog. Your code has to go in the new callback. There is nothing to disable.
(7,364 Views)
