Hide Description column, hide Settings column
Is there a way to hide (not show) the Step Description column and the Step Setting Columns?  This looks like (too much) debug info and I need it to go away or hide it.  TestStand 2020.
Message 1 of 8
(1,760 Views)
OK, I found a way to remove/hide the columns of interest.
A first time for everything.
Message 2 of 8
(1,728 Views)
Accepted by richjoh
This setting is saved in LocalAppData in SeqEdit.xml - just in case you need to copy this setting.
Michał Bieńkowski
CLA, CTA
Someone devote his time to help solve your problem? Appreciate it and give kudos. Problem solved? Accept as a solution so that others can find it faster in the future.
Make a contribution to the development of TestStand - vote on TestStand Idea Exchange.
Message 3 of 8
(1,715 Views)
Thanks. Excellent tip since I need to deploy automated test stations.  This can be programmatically done with the installer.
Message 4 of 8
(1,708 Views)
See this: https://github.com/425J/LayoutLoader
You might find this useful.
Michał Bieńkowski
CLA, CTA
Message 5 of 8
(1,701 Views)
In the attachment, you will also find an example of how to delete columns programmatically.
Michał Bieńkowski
CLA, CTA
Message 6 of 8
(1,697 Views)
Michal,
Can you make your sequence file TS version 2020.  I'm not using 2021 as yet.
Thanks for the tip.
One more thing, I haven't found a way to make the "Step Settings" go away and don't show.  I close it, run a sequence, return to and its back.  Let me know if there is a way.
Message 7 of 8
(1,520 Views)
So I discovered "Step Settings" will stay out of view only if it is Resize to a line then click X to close.  When it reappears after a sequence run it will appear as a line again with the X shown.
Not a 100% solution but it is out of the way. I wanted a way to make Test Setting disappear during and after a sequence run.
Message 8 of 8
(1,514 Views)
