11-12-2021 08:57 AM
Is there a way to hide (not show) the Step Description column and the Step Setting Columns? This looks like (too much) debug info and I need it to go away or hide it. TestStand 2020.
Solved! Go to Solution.
11-15-2021 08:25 AM
OK, I found a way to remove/hide the columns of interest.
A first time for everything.
11-16-2021 03:21 PM
This setting is saved in LocalAppData in SeqEdit.xml - just in case you need to copy this setting.
11-17-2021 08:27 AM
Thanks. Excellent tip since I need to deploy automated test stations. This can be programmatically done with the installer.
11-17-2021 11:55 AM
See this: https://github.com/425J/LayoutLoader
You might find this useful.
11-17-2021 01:51 PM
In the attachment, you will also find an example of how to delete columns programmatically.
02-23-2022 03:52 PM - edited 02-23-2022 03:54 PM
Michal,
Can you make your sequence file TS version 2020. I'm not using 2021 as yet.
Thanks for the tip.
One more thing, I haven't found a way to make the "Step Settings" go away and don't show. I close it, run a sequence, return to and its back. Let me know if there is a way.
02-23-2022 04:27 PM
So I discovered "Step Settings" will stay out of view only if it is Resize to a line then click X to close. When it reappears after a sequence run it will appear as a line again with the X shown.
Not a 100% solution but it is out of the way. I wanted a way to make Test Setting disappear during and after a sequence run.
