NI TestStand
Hide Description column, hide Settings column
Is there a way to hide (not show) the Step Description column and the Step Setting Columns?  This looks like (too much) debug info and I need it to go away or hide it.  TestStand 2020.
(189 Views)
OK, I found a way to remove/hide the columns of interest.
A first time for everything.
(157 Views)
Accepted by topic author richjoh
This setting is saved in LocalAppData in SeqEdit.xml - just in case you need to copy this setting.
Michał Bieńkowski
CLA, CTA
Someone devote his time to help solve your problem? Appreciate it and give kudos. Problem solved? Accept as a solution so that others can find it faster in the future.
Make a contribution to the development of TestStand - vote on TestStand Idea Exchange.
(144 Views)
Thanks. Excellent tip since I need to deploy automated test stations.  This can be programmatically done with the installer.
(137 Views)
See this: https://github.com/425J/LayoutLoader
You might find this useful.
Michał Bieńkowski
CLA, CTA
(130 Views)
In the attachment, you will also find an example of how to delete columns programmatically.
Michał Bieńkowski
CLA, CTA
(126 Views)
