NI TestStand
Has anybody used Averna Launch 2025 with Teststand 2024?
I'm running a sequence file in Teststand 2024. The standard Teststand report comes out without any issue, but if I disable the Standard Report and enable Averna Report, the report generation always give me error:
Parameter 'ReportInfo':
Unknown variable or property name 'RunState.Root.Parameters.ProductName'.
Below is the screenshot:
The same error message appears twice. After clicking OK (twice), Averna Report still shows up.
Has anybody seen this error before? How to fix it? I'm new to Averna and Teststand. Any help would be appreciated.
(468 Views)
I don‘t know Averna software… my guess is that it needs a proprietary ProcessModel.
The error you are seeing basically says, that a Property from the ProcessModel is missing
(433 Views)
Thank you for trying to help and making my post not feeling alone anymore. 🙂
I've switched to getting report directly from Averna. So the issue has become less important.
(422 Views)
