NI TestStand
HP Quality Center
One question. Is there anybody who was using some VAPI-XP-TEST script from HP Mercury Quality Center (former Test Director), in order to colect Pass-Fail results from a TestStand sequence?
If not. One more question. How can I execute in a command line a TestStand sequence that has defined its own parameters inside? Maybe I could pass those parameters values somehow to my script. Even if this could be difficult since they are defined between quotation marks and this can be seen by the script as pure text.
I will add this kind of script as an attachement. There is a XTools.run line which will execute the teststand sequence from a command line.
Thank you.
Message 1 of 1
(5,389 Views)
