NI TestStand
Global for Custom Step type
Hi All,
Can we use LabVIEW global variable or Function Global to pass data between two custom step type ?
For example:
I have a Custom step Type called Start Instrument , Where I m reading a file and storing the data into a global variable .
The second Custom step is Read Instrument ,where I should be able to get data from the global variable which I used in my Start Instrument Custom Step.
I tried this , but I think both step type are opening different global reference.
What is the preferred method without using TestStand Variable?
-Vipinraj
(1,170 Views)
Hi Vipin,
The globals should work ( i have not tried with LV but used it in CVI).
The other option is write the value to a file...maybe ini file.
Is there a specific reason why you dont want to use the TS variable.
Ravi
(1,106 Views)
