Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
07-03-2018 01:39 AM
Hi All,
Please let me know if there is any Sequence or Sequence File property to programmatically find if the current sequence loaded in teststand is saved or not.
Thank You,
Sree Ranjani.
07-03-2018 03:55 AM
Hi Sree,
You could check to see if the sequence file has been modified, using the following expression:
RunState.SequenceFile.AsPropertyObjectFile.IsModified
I hope this helps,
Charlie
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
Thanks!
We'll be in touch soon!
