09-22-2010 09:04 AM
A customer wants a small change to a previous deployment.
They have returned the original sequence file to me but the deployment is about two years old.
Is there anyway that I can get the TestStand Version number from the old sequence file so that I will know which version to save it in.
I am currently using TestStand 4.2.1.83.
Sean
Solved! Go to Solution.
09-22-2010 09:13 AM
Sean,
you can open the seq-file using wordpad and take a look.
hope this helps,
Norbert
09-22-2010 09:31 AM
There's a lot of strange characters but it says "4.1 (4.1.0.228)" in the first line.
I'm assuming that's the version number.
Thanks a lot Norbert.
Sean
09-22-2010 10:39 AM
Just want to add, there is also an API for this in the Engine, however if you just need to check a few files manually then what Norbert suggested is probably easier. The API is:
String fileVersion = Engine.GetFileInformation(filePath).GetFileFormatVersion();
Hope this helps,
-Doug
08-24-2014 07:48 AM
What if the sequence file is in binary format, not INI style?
You see rubbish when open it with a text editor.
This is a possibility after some version of TS.
08-25-2014 02:07 AM
As Sean stated back in 2010, you can also read the version number in clear text. You can read some parts of the file in a text editor, the version number is one of those....
Norbert
