Getting error code Hex 0xBFF63134
Hello All,
I am getting error:
XNET Database Create (Frame).vi:450001
NI-XNET:  (Hex 0xBFF63134) A frame with the same name already exists in the cluster. Solution: Use another name for this frame.
While using the vi of CAN in NI test stand. Although if i run this Vi alone its working good.
(668 Views)
The error is related to Frames having empty or no signals. To fix this, use the XNET Database Editor to edit the frames.
Alternatively you can convert the database to a xml format and edit the frames from an xml editor.
(624 Views)
