07-14-2021 01:17 PM
I would like to find the TS report filename, but DURING the test (ideally at the beginning of the main sequence).
I am generating several data files during the run, and I would like these files to have the same base filename as the report so that they match and can easily be determined.
I suppose another way to do this is to build the name from the start time. If that's the case, can someone point out where that is kept?
07-15-2021 07:51 AM - edited 07-15-2021 07:52 AM
Here I attached an example of how to do it.
Basically, it does following:
1. Searches for configuration of NI_ReportGenerator plugin in your model
2. Retrieves the full report path for your current socket
Roman
07-15-2021 12:59 PM
I'll take a look, thanks!
07-15-2021 01:02 PM
Fantastic! And it helped me figure out how to search through the plugin list. Outstanding!
