NI TestStand
Get step names from Outside running Sequence
I have been trying to get the step names from a Sequence, but thru a different sequence.
I know How to get them from the running sequence:
RunState.Sequence.Setup[Locals.Counter].Name
For this case Im getting the names from the Setup group, using a counter to iterate from all the avaliable steps in the Setup group.
But I'm still unable to get it from and outside Sequence. I have tried the following
Locals.SEQREF= RunState.Engine.GetSequenceFileEx(Parameters.SEQUENCENAME+".seq", GetSeqFile_FindFile, ConflictHandler_Error)
Locals.SEQREF.AsSequenceFile.GetSequence(Locals.Counter).Name
but with this approach I got all the Sequence Names available in the Sequences
and I just want to get the names called in the Setup, Main and Cleanup groups
in advanced thanks for the support
(949 Views)
Accepted by topic author LuisFuentes
The Locals.SEQREF.AsSequenceFile.GetSequence(Locals.Counter).Name will indeed give you the names of  sequences in your file. But you want to get the names of steps in Setup,Main,cleanup stepgroups of some particular sequence.
This is what you need:
ThisContext.SequenceFile.GetSequenceByName("Name of your sequence").GetStep(Locals.SomeCounter,StepGroup_Setup).Name
Roman
(898 Views)
Thank You!!!
(861 Views)
