I am using Teststand 2.0.1 and LabView 6.1.
I would like to read from the code if the test is running a sequence or if just a single step is running.
In the old Test Executive you could read a variable called get_gtx_state, is there a similare variable in Teststand ?
Thank you in advance
//Johan
Best Regards
Johan
