03-31-2020 05:26 AM
Hi All,
I want to know if ti's possible to get a reference of the current opened sequence in sequence editor from a sequence launchend from the tools menu.
I want to build a generic tool to change some properties of any sequence opene. Place my tool in tools menu seems to be the easiest way.
Any suggestion ?
Thanks for your help
Maxime R.
CLA - Certified LabVIEW Architect / Architecte LabVIEW Certifié
CTA - Certified TestStand Architect / Architecte TestStand Certifié
Solved! Go to Solution.
03-31-2020 09:28 AM
Hi Maxime,
I believe the following reference will get you what you want: RunState.InitialSelection.SelectedSequences
I hope this helps.
-Jack
04-01-2020 01:59 PM
@Captain_jack
Thanks a lot, you saved me a couple of hours.
Best regards
Maxime R.
