10-23-2020 05:33 PM
Anyone have examples/scenarios using custom Front-End Callbacks other than the basic login? Just curious on how others might call and use this type of callback.
Thanks in advance for any info.
Solved! Go to Solution.
11-02-2020 01:58 PM
I've used it many ways. Here are several:
Is there something specific you are looking for?
11-02-2020 02:27 PM
Thanks @jiggawax for your examples.
I worked on custom login UI this week similar to what you mentioned. I was more asking if other develops used the front-end callback other than login scenarios. It appears that is mainly the purpose and the examples/docs only mention login.
11-03-2020 10:14 AM
I think you are correct. The engine only looks for the loginlogout sequence inside of the sequence file. I'm guessing you could put your own sequences in there but then you would need to invoke it. So basically a custom system.
11-03-2020 10:23 AM
Calling it "front-end" is a little confusing if it is mainly used for login/logout. It seems like if it was for only login/logout, the sequence would be named as such and then the Sequence Editor could have other Front-End Callbacks with other sequences (located in the FrontEnd folder) for other features (menu clicks, etc.).
Anyways. Thanks for providing some of your examples. I was able to review and get some custom login things working, as well.
I'll keep this thread open a little longer just in case others want to chime in.
-Greg
11-03-2020 10:34 AM
I can't think of much else sensible to do there.... anything that you want global to that instance of the engine but don't want to lock into your UI? Maybe these:
Hope this helps!
Trent
