I would like to be able to find the file path and name of a teststand sequence in the process model. I have created a simple vi which will display this information when run in a sequence. If i insert the vi into the process model, the file path and name returned is that of the process model and not the sequence under exectution. Is there a way of extracting this information in the process model?
